Lyenyo
Apr 28, 2019Aspirant
WiFi dropping (LAN is fine)
Hi all, I purchased this system in November to resolve WiFi signal at the back of the house. I have absolutely fantastic signal now but unfortunately within the past 2 months I’ve been having sporadi...
Apr 29, 2019Guru - Experienced User
Lyenyo "What is the distance between the router and satellite(s)? 1 ceiling and 15ft between router and satellite 1 and then 25ft between satellite 1 and 2. Devices connected to Sat 2 have max WiFi signal on indicators. Distance is too close. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What channels are you using? Channel 7 for 2.4Ghz and 36 for 5Ghz. " Try setting manual channel 1, 6 or 11 on 2.4Ghz
