Jeannet
Oct 19, 2021Tutor
Wifi dropping out - Do I need to update the software - How?
Dear All, I bought an Orbi AC3000 Tri-band WiFi Add-on Satellite(RBS50) in July '17, so it must by now be an old model. It has a network extender and one satellite. The extender is connected via wi...
Jeannet
Oct 20, 2021Tutor
Sorry, Furrye38, I was unclear in my posting.
I have a Virgin router, an ORBI extender RBR50, which is connected to the Virgin router with an ethernet cable, and to which the Orbi sattelite is connected via Wifi, synched using a WPS button.
I have spoken with Virgin who are sending out an engineer to see what's going on. I'll let you all know the diagnosis and hopefully the solution!
Thanks again for your support!
Jeannet :-)
Oct 22, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2, if not then Option #3.
Jeannet :-)
