netblokeusa
May 16, 2021Aspirant
WiFi dropping sporadically
I have gone through these forums looking for a solution.... So I use Xfinity. My Cable modem is an Arris SB8200. It seems that my WiFi is a sporidically dropping (and has been for some undet...
netblokeusa
May 17, 2021Aspirant
Sorry Orbi Router is RBR750 (purchased through Costco if that makes a difference)
Firmware Version V3.2.18.1_1.4.14
I never notice anything connected to the main router dropping but from satelites yes.
For WAN Port integration do you mean this setting? I have internet port selected.
| WAN Preference |
| Internet Port (1 Gbps) |
| WAN aggregation (1 Gbps + 1 Gbps, LACP-IEEE802.3ad) |
May 18, 2021Guru - Experienced User
You might get more help in the orbi ax forums as the users are more familar with the Orbi AX. I don't have one so can't attest to how well they work/firmware issues with them.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
One thing I would advise, don't use the 2nd port on the sb8200 with other devices or wan port aggregation. Its known to have issues with xfinity (drops).
- netblokeusaMay 18, 2021Aspirant
thanks I will try that
