liteuser
Jul 15, 2020Aspirant
wifi dropping,
Hi all I have read through some of the posts already posted on here to help fix my issues, with no success. I am sorry if this is duplicated some where............ Here is my situation....... ...
Jul 15, 2020Guru - Experienced User
Your home hub would be a router here. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 first.
I would change out the CAT5 cable for CAT6 cable. I recommend running same CAT level for all cabling.
- liteuserJul 15, 2020Aspirant
Hi Furrye38
thank you soooo much for the info, I really appreciate your time in responding.
i have spent at least 5 hours today,what feels like me going round and round in circles and achieving nothing.
i really hope it works as I love the thought of every room having Wi-fi, the ring cameras connecting with good reception etc. And I would like to put an outdoor orbi in the garden.
I will pick up some cat 6 network cables tomorrow. I will then go for option 2 as you have recommended..
BTW....
I have just got my hands on a TP-link ac1200 modem router, model number. Archer VR400,,,,,, would this be better to use instead of the Bt smart hub 2 or does it not matter about what the orbi is 'plugged" into ?
- FURRYe38Jul 15, 2020Guru - Experienced User
EIther model will work. However since these modems have a built in router already, these either need to be bridge fully do the Orbi router is the only router online, or try option #2 with the modem and Orbi router, or you'll need to configure AP Mode in option #3.
