Mkstretch
Jul 28, 2020Aspirant
WiFi dropping
I had a blackout the other day and since then my work VPN is losing connection periodically, and my security system daily test is showing abnormal WiFi tests. Is their a way to test for issues? Or do...
DarkNet
Jul 28, 2020Apprentice
I guess it’s possible that after your power outage, your system came back up with default settings instead of a custom setting or settings you had in place. You might go through and double check your configuration.
