Mkstretch
Jul 28, 2020Aspirant
WiFi dropping
I had a blackout the other day and since then my work VPN is losing connection periodically, and my security system daily test is showing abnormal WiFi tests. Is their a way to test for issues? Or do...
Mkstretch
Thanks guys I'll check this all out. Also I'm using my orbi in AP mode with my Verizon quantum gateway router if that matters. I'm running the latest firmware. I'm on auto channels.
- FURRYe38Jul 28, 2020Guru - Experienced User
Be sure any wifi on the verizon gateway is disabled fully as well.
Let us know about the other suggestions.
- MkstretchJul 29, 2020Aspirant
Ok. Also my house is 3900sq ft. Is it better if I hard wired one of my satellite?
- FURRYe38Jul 29, 2020Guru - Experienced User
Yes you can. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Be sure to disable Diasy Chain on the RBR.
