Mkstretch
Jul 28, 2020Aspirant
WiFi dropping
I had a blackout the other day and since then my work VPN is losing connection periodically, and my security system daily test is showing abnormal WiFi tests. Is their a way to test for issues? Or do...
Jul 28, 2020Guru - Experienced User
Be sure any wifi on the verizon gateway is disabled fully as well.
Let us know about the other suggestions.
Mkstretch
Jul 29, 2020Aspirant
Ok. Also my house is 3900sq ft. Is it better if I hard wired one of my satellite?
- FURRYe38Jul 29, 2020Guru - Experienced User
Yes you can. https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
Be sure to disable Diasy Chain on the RBR.
- MkstretchJul 29, 2020Aspirant
stupid question. My rbr is plugged into a switch on the first floor and the satellite I would hardwire to a switch on the second floor. Would this work?
As long as the ethernet switch and cable line is connected behind the RBR for the RBS connection. The RBS needs a connection behind the RBR.
So> Modem to > RBR> RBS. Or Modem to > RBR> switch to<>RBS
