ramair02
Nov 09, 2020Aspirant
WiFi Drops / Disconnects (Orbi RBK50 AC3000)
I'm having some issues with dropped connections. Sometimes on my phone I'll notice a full disconnect -- WiFi network drops, switches to LTE then a minute or so later the WiFi connects again. But on m...
Nov 09, 2020Guru - Experienced User
Basements are not recommended places for wifi routers. Concrete and steel inhibits wifi signal travel and good performance.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- ramair02Nov 10, 2020Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Basements are not recommended places for wifi routers. Concrete and steel inhibits wifi signal travel and good performance.
Firmware: V2.7.0.70
Verizon FiOS ONT: I-211M-L
Unfortunately, the basement is my only choice since that is where Verizon installed the ONT and the house doesn't have ethernet wiring to any other location.
The distance between my RBR and RBS is at least 30 feet.
- FURRYe38Nov 10, 2020Guru - Experienced User
If you turn OFF the RBS, does the problem continue?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Has a power off for 1 minute then back on been performed since last update?
Has a factory reset and setup from scratch been performed since last FW update?There is a more recent FW update for v2.7x on NG update web site...
- ramair02Nov 10, 2020AspirantIf I turn off the RBS, I still experience the dropouts.
I do have neighbors close by. My home is in a suburban neighborhood. I've attached pics from WiFi Analyzer.
https://photos.app.goo.gl/6iHWMTRcA5YVa9Vh9
I have factory reset and set up from scratch. I will check for a firmware update. It didn't find one when I last checked a couple of days ago.
