Erwin_S
Feb 17, 2021Aspirant
Wifi drops after 2.7.2.104
Hi, after updating my Orbi recently to 2.7.2.104, the WiFi connection seems to be instable. On my iPad devices for example, wifi is regulary disconnected. Trying to reconnect leads to al long l...
vajim
Feb 17, 2021Master
you may want to revert your firmware
lots of problems with 2.7.2.104
you can do a search
Ha_Ku_Na
Feb 17, 2021Luminary
vajim wrote:you may want to revert your firmware
you can do a search
This is not true, from my point of view.
Usually only problems are reported here in the forums, but seldom successfull updates.
2.7.2.104 is the most stable firmware since 2.5.1.16, the only issue I recognized:
- connection speed in Orbi App is missing for devices not connected to RBR
- but Orbi App (iOS) is anyway not recommended (my personal opinion)
- vajimFeb 17, 2021Master
you can do a search
Thanks for your opinion. A simple search here will prove otherwise. IF your update to this firmware was so successful, why wait to post a counter comment? As you said, perhaps this forum does need more successful posts. The caution to that would be to include system setup, devices, update procedure, etc. To simply say the firmware is good is not always true. My comment is only posted on years of watching others in here dive into a firmware update only to return in a few days wishing they hadn't. Lets bring on the successful update details.
- Ha_Ku_NaFeb 17, 2021Luminary
I guess, I posted more informative information in my few posts than you over "years".
Most of your posts are not helpful, also my personal opinion ;-)- vajimFeb 17, 2021Master
Ha_Ku_Na wrote:Thanks for your opinion. A simple search here will prove otherwise. IF your update to this firmware was so successful, why wait to post a counter comment? As you said, perhaps this forum does need more successful posts. The caution to that would be to include system setup, devices, update procedure, etc. To simply say the firmware is good is not always true. My comment is only posted on years of watching others in here dive into a firmware update only to return in a few days wishing they hadn't. Lets bring on the successful update details.
Most of your posts are not helpful, also my personal opinion ;-)help is in the mind of the beholder. personal attacks are from the devil
