Erwin_S
Feb 17, 2021Aspirant
Wifi drops after 2.7.2.104
Hi, after updating my Orbi recently to 2.7.2.104, the WiFi connection seems to be instable. On my iPad devices for example, wifi is regulary disconnected. Trying to reconnect leads to al long l...
vajim
Feb 17, 2021Master
FURRYe38 wrote:Try a full power OFF of the RBR and RBS and modem for 30 seconds then back on.
IF this does work, is it a part of the firmware update instructions provided by Netgear?
vajim
Feb 17, 2021Master
- ngautobotMar 25, 2021TutorAfter updating to 2.7.2.104 my connections are very flaky. How do I revert? I cannot find specific information on how to. Thanks!
- vajimMar 25, 2021Master
ngautobot wrote:
After updating to 2.7.2.104 my connections are very flaky. How do I revert? I cannot find specific information on how to. Thanks!If you've tried all the great suggestions to fix the problem, you can go to the download area, enter your model number and see what's there.
