Gabe777
Jun 26, 2021Tutor
WiFi drops and reconnects intermittently
Hi, I have an Orbi rbr20 router with 3 satellites. WiFi is inconsistent with it dropping and reconnecting throughout the day. I’ve had the hardware for over 1 year. I have latest firmware for both ha...
Jun 26, 2021Guru - Experienced User
has it been dropping the entire year?
Is this something new?
What modem/gateway do you have?
What actual firmware version are you on?
how big is your home ?
how far apart are the router/satellites from each other? (30 ft mimimum is recommended)
are they connected to each other using wireless/wired backhaul?
are they running through a switch (if so what switch)?
- Gabe777Jun 26, 2021TutorThanks for your reply. Yes, new problem. WiFi problem within last 1.5 months. Orbi setup done over 1 yr ago.
-ATT gateway
-Orbi RBR20 firmware 2.6.2.104
-3 level home about 1800 sq feet
-3 satellites connected wirelessly
-all connected less than 30 ft
-don’t understand what it means to run through a switch
-Orbi router connected with Ethernet cable to att modem (1gb fiber), Orbi router is an access point I believe.
*Can this recent WiFi problem be due to frequency or channel interference? No new hardware or update was performed recently to cause the problem. Thank you.- plemansJun 27, 2021Guru - Experienced User
-ATT gateway---which gateway? ATT is notorious for using modem/router combo devices. Cascading multiple router is a recipe for issues. Its called a double nat. And ATT makes it so getting their devices in passthrough/modem only mode is a pain/doesn't work properly. Many end up with their orbi running in AP (access point) mode. https://kb.netgear.com/30186/What-is-Double-NAT
-3 level home about 1800 sq feet---1800sq ft total or each floor? If its total, 3x satellites is probably to many unless your home is made from brick/concrete/plaster lathe/adobe
-all connected less than 30 ft----that's to close. they need at least 30ft between them.
-don’t understand what it means to run through a switch----some people hardwire in their satellites with a wired backhaul. I've seen some switches have issues/cause instabilities.
-Orbi router connected with Ethernet cable to att modem (1gb fiber), Orbi router is an access point I believe.---is it actually in access point mode? it wouldn't be the first time a firmware upgrade caused a setting to change.
*Can this recent WiFi problem be due to frequency or channel interference? ---its always worth a chance at trying to change the wireless channel. No new hardware or update was performed recently to cause the problem. Thank you.- Gabe777Jun 27, 2021Tutor1. ATT Arris BGW210. It was setup in passthrough mode and confirmed with ATT tech support when I installed the Orbi router over 1 yr ago.
2. I’ve confirmed yesterday that Orbi router is still in AP mode
3. 1800 ft total. I mistyped earlier. Each satellite is at least 30 ft apart. One on each floor.
4. I’ve changed the 2.4 to channel 11, 5 ghz to channel 46 yesterday.
