Gabe777
Jun 26, 2021Tutor
WiFi drops and reconnects intermittently
Hi, I have an Orbi rbr20 router with 3 satellites. WiFi is inconsistent with it dropping and reconnecting throughout the day. I’ve had the hardware for over 1 year. I have latest firmware for both ha...
Jul 04, 2021Guru - Experienced User
Router mode if your using the ISP Modems IP Pass-Thru feature.
Gabe777
Jul 04, 2021Tutor
Thank you for your support. My current setup is Att gateway (passthrough) < Gryphon mesh router < Orbi router (AP mode). Should I still change the Orbi to router mode?
- FURRYe38Jul 04, 2021Guru - Experienced User
If you have a router infront of the RBR then AP mode is fine.
- Gabe777Jul 05, 2021TutorThank you for confirming the AP mode. Any other recommendations in correcting the intermittent WiFi drops?
- FURRYe38Jul 06, 2021Guru - Experienced User
I'd turn OFF the RBS, run the RBR alone and observe to see if the wifi continues to drop...
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless SettingsOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
