surlymac
Jun 26, 2019Aspirant
Wifi drops every 1-3 minutes after power outage
After a 2 hour power outage 4 days ago, all my wifi devices now only stay connected to my RBK50 system for 1-3 minutes. Some reconnect automatically, and some don't. The SSID is not visible for 30-60...
Jun 26, 2019Guru - Experienced User
20 feet is a bit too close between the RBR and RBS.
As suggeested, you might configure the modem for router mode and disable ALL wifi on it, then configure the RBR up for AP mode and see if this changes anything. I would do one more factory reset. This time, don't add the RBS. Leave it off. Just the RBR. Test the wifi stability and see if the wifi remains or keeps going off line.
