hhuang88
Oct 05, 2019Follower
WIFI Extender EX2700 connect to ORBI RBR20
Trying to connect the EX2700-100PAS to the ORBI RBR20 router. The green light "router" is on, but the "device" light is off. So can't connect to the SSID "X_ext". 1. can anyone tell me if this com...
Oct 09, 2019Guru - Experienced User
Some EXs may not be compatible. I and a few others couldn't get EX8000 or 7700 to connect. NG updated FW on those models. I would contact NG support to see if this is possible for your model EX.
