Waugust
Mar 13, 2023Aspirant
Wifi extender for Orbi RBR50?
I have stability problems with one pair of Sonos speakers wifi connected to my network. All other Sonos speakers in various locations throughout the house work fairly well. My system is an Orbi RBR50...
- Mar 13, 2023
I would expect the WiFi signal strength standing about 3-4 feet from an RBR50 to be in the range of -32dB to -35dB. A reading of -45dB seems a bit low. (but still "excellent") a reading of -75dB counts as "not good".
If the problem has disappeared, then moving the speaker 12 feet appears to be the solution.
Waugust
Thanks for the replies.
Not sure I'd characterize coverage throughout the house as "good", certainly not great. Using the Orbi app wifi analyzer, I found that signal strength standing in front of one of the ethernet connected satellites was 84%, -45dBm. DK if that is what I should expect or not. When I moved 32 feet to the problem speakers in the kitchen (straight shot, no walls in between) signal strength dropped to 48% -75dBm. Moving one of the two kitchen speakers 12 feet closer to the satellite, still in the kitchen, the reading was 48% -65dBm.
I just started playing music on all Sonos pairs, all playing including the kitchen with the 12 foot closer speaker. So, proximity to the closest satellite seems to help.
I posted a detailed description of my network setup on the Sonos community site, and could duplicate it here if you think it would help. The main takeaway is about the wifi stats and the fact that (so far) there hasn't been a dropout having moved one of the two kitchen speakers 12 feet closer to the satellite.
