Stallion69
Oct 02, 2020Tutor
Wifi Extender
I currently have a few dead spots in my house and i am using the Orbi RBR50 with Router and 2 satellites. The router is located in the basement, and the two satellites are loacted on main floor. I ...
CrimpOn
Oct 02, 2020Guru - Experienced User
Stallion69 wrote:I currently have a few dead spots in my house and i am using the Orbi RBR50 with Router and 2 satellites. The router is located in the basement, and the two satellites are loacted on main floor. I wanted to extend the wifi signal in the basement and also a section of the the main floor. What should i use? Doesn't ORBI sell the (plug in's) that extend the signal?
The original Orbi satellites appear to be in short supply (almost impossible to find). On the recommendation of Mstrbig , I picked up a RBS40V (voice) from Amazon for $99. Least costly solution and works perfectly. (So far, I have resisted the entreties to activate Alexa on it.)
Stallion69
Oct 03, 2020Tutor
So this Unit will extend one of my ORBI satellites? I currently have an Alexa ECHO in my kitchen, and i can replace it with this one as long as it will boost my ORBI Satellite signal. Is this statement correct?
