Jsnyder2003
Aug 20, 2019Aspirant
WiFi firmware update errors
Trying to check for firmware update and it always says error...
Aug 20, 2019Guru - Experienced User
Are you checking FW updates with the Orbi app or with a PC and web browser connected to the RBRs web page? Using the PC and web browser is perferred.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Are you streaming 4K over a wireless or wired connection?
