Nisheel
Dec 25, 2017Aspirant
Wifi goes OFF everytime I reboot the router
When i reboot my router the wifi network goes off (see the attached screenhot). Also network password is a 10 digit password mix of alphabets, numbers and special characters but the admin screen onl...
aaz
Dec 28, 2017Virtuoso
I would say your firmware was not updated properly in the first place. You have a broken config and the lower firmware is just masking it. You should update all over again taking care to update satellites first and then the Router after with the proper firmware for each device.
If it's still broken you need to reset to factory defaults and re-setup everything.
Nisheel
Jan 08, 2018Aspirant
aaz Firmware is fine. See IT_fooly post. This is the issue.
aaz wrote:I would say your firmware was not updated properly in the first place. You have a broken config and the lower firmware is just masking it. You should update all over again taking care to update satellites first and then the Router after with the proper firmware for each device.
