ivankenzo's avatar
ivankenzo
Wifi Interference
When I connected to Orbi (AP name : Kenzo) and checked using Wifi Analyzer apps i see that the interference is 90%, is this normal?  I tried to change the channel but got the same result. channel  ...
  • plemans's avatar
    May 29, 2020
    The orbi router and satellites all use the same channels. So your wifi analyzer is seeing the other networks and thinking they're interference when its actually a design feature.
