MidTnMike41
Mar 15, 2019Aspirant
Wifi internet issues
The other night I noctied my phones were saying "Cannot obtian IP" while on wifi. The I tried to work for a little while and my work laptop would connect but would not get an IP address, so I had no ...
Mar 15, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
MidTnMike41 wrote:
The other night I noctied my phones were saying "Cannot obtian IP" while on wifi. The I tried to work for a little while and my work laptop would connect but would not get an IP address, so I had no internet. I unplugged everything and plugged it back and wifi was back. This morning same problems again. It seems to come and go. I updated to the latest firmaware this morning and still have same results. My orbi has worked perfect until the last week. Nothing in my network has changed. Any suggestions to resolve this issue?
- MidTnMike41Mar 15, 2019Aspirant
Thats a lot of questions, I'll try to hit them all.
Both router and satalite are on 2.3.0.32
Home is about 2700Sq Ft, normal wood, drywall contruction, satalite is about 30 ft away with good signal
2.4 is on auto, with a lot of neighbors near by, I usually see about 5 other wifi networks.
Security is WPA2-PSK [AES]
I just enabled the those two settings, I will test with my work laptop which seems to give the most problems. I have two android phones that come and go, but both are currently connected with no problems. Time will tell when I leave and come back.
- FURRYe38Mar 15, 2019Guru - Experienced User
If you have alot of wifi neighbors near by, could a some wifi congestion going on. I would try a manual channel on 2.4Ghz.
Let us know how it goes.
- MidTnMike41Mar 16, 2019Aspirant
I did a factory reset this morning and still have the same issue. I finally just put the orbi in AP mode, took my xfinity router out of bridge mode, and disabled the wifi on the xfinity router. That way now my xfinity router is doing all the DHCP and all the Orbi is doing is the wifi connections. While I wouldnt say this is a fix as much as a work around, it did solve my issue. All my devices are conecting again.
