WFH_Colorado
Jan 22, 2021Tutor
WiFi issues with cordless phones and Orbi
Hi community I have been experiencing wifi dropouts when a call is made or received on a cordless phone system. The phone are DECT 6.0 and operate at 1.9Ghz, brand new system. This happened with two...
Feb 22, 2021Guru - Experienced User
- WFH_ColoradoFeb 23, 2021Tutor
Reference I used was: https://approvedmodemlist.com/intel-puma-6-modem-list-chipset-defects/
From the bad list ....
XFINITY XB6-A (ARRIS TG3482G)
XFINITY XB7 (ARRIS TG4482)Note: the XFINITY XB6-T (Technicolor CGM4140COM) uses a Broadcom chipset, it is safe
Note: the XFINITY XB7 (Technicolor CGM4331COM) uses a Broadcom chipset, it is safeI switched to the CGM4331COM.
- FURRYe38Feb 23, 2021Guru - Experienced User
You should be good then.
Enjoy.
WFH_Colorado wrote:Reference I used was: https://approvedmodemlist.com/intel-puma-6-modem-list-chipset-defects/
