Mvmp103
Jan 11, 2021Follower
WIFI keeps breaking up RBR50
Since 3 days our Orbi keeps disconnecting and restarting the Wifi. It mentions "internet not secured" disconnects the Wifi and restarts the Wifi. The normal internet connection via LAN (cable) keeps...
Jan 11, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
