LateAdopter
Dec 12, 2021Aspirant
Wifi keeps dropping on RBR50
I have and RBR50 and 4 satellites (RBS50). I have had them for 2-3 years and they have the latest firmware. They were working fine but over the last few weeks have been dropping daily requiring me ...
- Dec 14, 2021
Are you sure the modem is bridged? Mighy check it's configuration.
Turn off and unplug modem.
Turn on computers and rest of network.Try this alternative, configure the modem back to router mode. Disable ALL wifi radios on the modem. Configure the RBR for AP mode. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
LateAdopter wrote:
I am not sure if it is anything to do with turning off daisy chain (don't think so) but now the internet is not working at all on the router (although it is on the ISP hub if I connect via LAN). This means wifi not working at all in the house at the moment
We have a meltdown situation which is causing me severe stress at the moment!
Streak2
Dec 12, 2021Master
Silly question but when you try to access Orbilogin.net are you sure that your wifi is connected to your Orbi system?
Can you try accessing the router settings by connecting a computer directly to the router using an ethernet cable?
Once connected then make sure that all devices have the lates firmware not just the router.
LateAdopter
Brilliant, thanks. My computer was actually connected via LAN cable to the ISP's router (to which the Orbi is connected) so I changed it to wired to the Orbi and can now access the portal. That is the second problem solved.
the first problem was working out why the wifi keeps dropping - i am having to do a reset every day. Any ideas?
- Streak2Dec 12, 2021Master
Satellites and router on the same version of firmware?
When you say the wifi is dropping is this only on one device? What about wired devices?
Is the problem only when connected to one of the satellites or all of them?
What's the backhaul status like and is it 2.4 or 5Ghz?
Star or daisychain topology?
- LateAdopterDec 12, 2021Aspirant
They are all on the same firmware, which is the latest version - v2.7.3.22
as for dropping, the wired devices are fine. It seems to be two of the satellites in particular which i have had complaints about from the family, but it could be all of them.
I have found in the advanced settings that Daisy-Chain topology is enabled.
I am afraid i am not very techy so can't out what the backhaul status is or whether it is 2.4 or 5 ghz. where would i find that?
On the orbilogin page select Attached Devices and it will shows you a screen with the satellites at the top with a column showing connection type and backhaul status.
If your router is centraly located with the satellites scaettred around it then disbale daisy chain.
In my case the router is one end of the house with the satellites strung out from there so I have daisy chain enabled.
