LateAdopter
Dec 12, 2021Aspirant
Wifi keeps dropping on RBR50
I have and RBR50 and 4 satellites (RBS50). I have had them for 2-3 years and they have the latest firmware. They were working fine but over the last few weeks have been dropping daily requiring me ...
- Dec 14, 2021
Are you sure the modem is bridged? Mighy check it's configuration.
Turn off and unplug modem.
Turn on computers and rest of network.Try this alternative, configure the modem back to router mode. Disable ALL wifi radios on the modem. Configure the RBR for AP mode. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
LateAdopter wrote:
I am not sure if it is anything to do with turning off daisy chain (don't think so) but now the internet is not working at all on the router (although it is on the ISP hub if I connect via LAN). This means wifi not working at all in the house at the moment
We have a meltdown situation which is causing me severe stress at the moment!
LateAdopter
Dec 14, 2021Aspirant
Dec 14, 2021Guru - Experienced User
- LateAdopterDec 15, 2021Aspirant
It turns out that the router was NOT set to bridge mode. Thanks for recommendaing i check again. I am sure it had been in the past, so perhaps it reset on an update. Once i sorted that, I reset the system and it is now working well
- FURRYe38Dec 15, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
