dubirl
Feb 25, 2017Tutor
Wifi keeps dropping
Replacing my 2 Airport Extreme APs & 1 Airport Express (one on each floor) The GND floor Airport Extreme was connected a SKY router. I relaced all the Airport fit with the Orbi router RBR50 and Sat RBS50 - set the Orbi router to AP Mode. I started to notice the network dropping, when I checked the logs on the SKY router its network port dropped the link - when I checked the log on Orbi the log was a new one. Also noticed when a new device is connected the wifi goes off-line.
Any ideas why the network keeps dropping?
- DarrenMSr. NETGEAR Moderator
Hello dubirl
You could try to change the wireless channels and see if that stops the drops or you may want to re position the satellite unit.DarrenM
- dubirlTutor
Hi Darren,
I changed the wireless channel made no difference - the satellite is not dropping, its the wired connect between the Orbi base station and the router that's dropping.
dubirl (Kieran)
Hello dubirl
Have you tried different cords and a different port on the SKY router?
DarrenM
- I have the same issue, on both IOS and Android devices. Updated to the latest firmware doesn't seems to fix the problem. Still getting signal drop and reconnect every few minutes.
