adenzxc's avatar
adenzxc
Wifi keeps dropping
My Wi Fi has been disconnecting every day for the past 5 days. My current router firmware version is  V2.6.2.104. I don't know much about internet/wifi settings, hence have not tweaked anything. I h...
  • svetaketu's avatar
    svetaketu
    Jul 26, 2021
    Hi adenzxc,
    No worries. Glad to help out.
    There are different ways NG can do the update:
    • Your router normally checks for new FW in the early hours of the morning - 3am i think. Once your router detects the new FW, then it automatically updates it if you set it to allow automatic updates.
    • or, if a new FW is available, it will show it as a banner on your App or on the GUI, and you have the choice to update or not.
    • or, there are also times where it will only show when you manually press the check new /latest FW from the App or GUI.
    • and last would be a manual FW update by downloading from the website.
    All of these are depending on the situation. Sometimes they will just make the FW available to only a select number of units for a few weeks, then will make it available to all units eventually. ***thats why you'll sometimes see some users here in the community getting the latest FW but some do not.
    Hope the latest FW fixes your issue.
