adenzxc
Jul 26, 2021Aspirant
Wifi keeps dropping
My Wi Fi has been disconnecting every day for the past 5 days. My current router firmware version is V2.6.2.104. I don't know much about internet/wifi settings, hence have not tweaked anything. I h...
- Jul 26, 2021
Hi adenzxc,
No worries. Glad to help out.
There are different ways NG can do the update:
- Your router normally checks for new FW in the early hours of the morning - 3am i think. Once your router detects the new FW, then it automatically updates it if you set it to allow automatic updates.
- or, if a new FW is available, it will show it as a banner on your App or on the GUI, and you have the choice to update or not.
- or, there are also times where it will only show when you manually press the check new /latest FW from the App or GUI.
- and last would be a manual FW update by downloading from the website.
All of these are depending on the situation. Sometimes they will just make the FW available to only a select number of units for a few weeks, then will make it available to all units eventually. ***thats why you'll sometimes see some users here in the community getting the latest FW but some do not.
Hope the latest FW fixes your issue.
adenzxc
Hi svetaketu,
Thanks for the prompt response. None for the above questions.I'll try a manual update to FW.
May i check if you know the reason why the firmware was not updated upon reboot/hard reset?
svetaketu
Jul 26, 2021Luminary
Hi adenzxc,
