Ponxs's avatar
Ponxs
Follower
Apr 15, 2020
Wifi Mesh
SO I have poor wifi speed due to a high density of routers in the area. I pick up at least 11 wifi signals. Will putting in an Orbi system help with this. curious before I purchase anything. I have tried changing chanels and it does not help.
  • Retired_Member's avatar
    Retired_Member
    I doubt your speed issue is due to your neighbors specifically.
    The Orbi does offer a more robust wifi (MESH) network over the standard when used with a Sat.  Even so, setting the wifi channel to AUTO is your best bet.  Setting your wifi channel to a specific channel in most cases is a waste of time for chances are your neighbors are doing the same.
    Wifi speed has many factors involved.
  • You can turn down the power output of the wifi radios on your current router to see if this helps any, if your router supports this. Helps in reducing the interferences seen when in a wifi congested area or environment.
