Kevberry
Dec 28, 2021Aspirant
WiFi network without cellular AX4/AX1800
Hi, Will this router operate the WiFi network without a sim card or when out of cellular service? I want to be able to link devices on the wifi network and dont always have cell coverage. This is an...
Dec 29, 2021Guru - Experienced User
You might have better luck with the forum for that specific device where there might be users that have that model.
I'll notify a mod to move the post but it can take a bit.
- KevberryJan 05, 2022Aspirant
Thanks for your reply, no other suggestions so far.
- FURRYe38Jan 13, 2022Guru - Experienced User
Yes it should since it does have a WAN port in back that you can connect to a ONT, Cable or DSL modem:
https://www.netgear.com/images/datasheet/networking/wifirouter/LAX20.pdf
