Kevberry
Dec 28, 2021Aspirant
WiFi network without cellular AX4/AX1800
Hi, Will this router operate the WiFi network without a sim card or when out of cellular service? I want to be able to link devices on the wifi network and dont always have cell coverage. This is an...
Kevberry
Jan 05, 2022Aspirant
Thanks for your reply, no other suggestions so far.
Jan 13, 2022Guru - Experienced User
Yes it should since it does have a WAN port in back that you can connect to a ONT, Cable or DSL modem:
https://www.netgear.com/images/datasheet/networking/wifirouter/LAX20.pdf
