MrMcMann
Sep 20, 2018Follower
Wifi Network
Hi, I have the AC1600 Wifi cable modem and router and have some deadspots in my home and would like to create a mesh network with the new orbi. My question is do i have to purchase a complete system ...
Sep 21, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
MrMcMann wrote:
Hi, I have the AC1600 Wifi cable modem and router and have some deadspots in my home and would like to create a mesh network with the new orbi. My question is do i have to purchase a complete system with modem and router for the orbi? Or can I purchase one orbi and use my exisiting modem/router? would they be compatible?, and if so how do i do that without having to hardwire anything. I would rather it be a wireless mesh network rather than create a hardwire access point.
