Carbs314
Oct 21, 2022Follower
Wifi not connecting to main SSID
I had a power failure and when my orbi came back the only way i can use Wifi was access the guest network i had setup. Every device in my house wont connect to the main SSID. I have rebooted the mai...
Oct 21, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
