Zuhair2008
Dec 05, 2018Tutor
Wifi Off every 5 mins !!
Hello I just bought RBK53, WiFi signal is turning OFF and ON every 1-5 sometime every 45 minutes and I don't no what's the solution. Firmware Version V2.2.1.210 ..
Zuhair2008
Dec 06, 2018Tutor
My connection is Fibre .. I'm using Huawei EchoLife HG8245Q , there are two devices connected to it
Wired :
1- Huawei EchoLife HG8245Q --> RBR50 .
2- Huawei EchoLife HG8245Q --> TP-Link Powerline 1 --> connected to TP-Link Powerline 2
nothing wired connected to RBR50
ekhalil wrote:
Zuhair2008 wrote:
Hello
..What wired devices do you have connected to Orbi? Any mesh speakers (e.g. Sonos)?
Dec 07, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Wired :
- Zuhair2008Dec 07, 2018Tutor
I tried step 3.. Nothing changed.
Is there anyway to make two different ssids names? One for 2.4 and the other for 5.0 ? Maybe this step will fix the problem.
FURRYe38 wrote:
Modem Combo Units:
Couple of options,
Wired :
- FURRYe38Dec 07, 2018Guru - Experienced User
Separating SSIDs is not supported on the orbi, though there is a couple of threads regarding users separating the SSIDs on the Orbi.
You shouldn't have to do this however.
You sure the Wireless is disabled and fully OFF on the ISP modem?
Any other wifi sources near by?
What happens if you turn down the wireless power output on the radios, found under Advanced Tab/Advanced/Wireless settings?
Also set a manual channel 1, 6 or 11 on 2.4ghz.
I presume nothing works to help this, you may have a bad system and would need to be RMAd.
- Zuhair2008Dec 08, 2018Tutor
I changed the channel from auto to 11.
More than 3 hours everything working great .. if the problem still there I will inform you.
Thank you for your support
Can I ask you what do you mean with RAMd ?
