woodsjay
Sep 01, 2018Aspirant
Wifi password doesn't work
According to the label on the bottom, this is an orbi mini router RBR40. Note that this model isn't listed in the Model field above. My computer is a Dell Latitude E6520 running Fedora 28. The hardwi...
rogger007
I do not know what is the cause behind this issue. I have also asked Router Supports for help. I am just waiting for there reply. If anyone from here can help me out then it will be fine for me.
michaelkenward
Sep 02, 2018Guru - Experienced User
Health warning, Router Supports is an external website that has nothing to do with Netgear.
It is well known that some of these sites are there just to relieve you of money. They are not affiliated with official support. If things go wrong when you use them, you cannot blame Netgear.
Netgear itself does not provide paid-for support. It farms that out to GearHead Technical Support.
But if you are within 90 days of buying your device you are eligible for free support via Netgear.
