rezy
Nov 26, 2018Aspirant
Wifi performance suddenly poor
Need to know if it is common for certain things to get bogged down when there is to much connected to the router and one satalite? I have recently added two amazon echo's and now my nest app is start...
Nov 26, 2018Guru - Experienced User
What FW is currently loaded?
How many devices do you have connected? Has it been working well up until you installed more devices.
- rezyNov 26, 2018Aspirant
and satalite
there are 20 devices connected
- FURRYe38Nov 26, 2018Guru - Experienced User
are they all connected to the router base or satelllite or mixed connections?
What is the Mfr and model# of the ISP modem the NG router is connected too?Was the system working well before you added more devices?
they are probably connected to the base, I do not know how to connect them just to the satalite
what is fw?
yes the system was fine until I added amazon echo's
