rezy
Nov 26, 2018Aspirant
Wifi performance suddenly poor
Need to know if it is common for certain things to get bogged down when there is to much connected to the router and one satalite? I have recently added two amazon echo's and now my nest app is start...
rezy
and satalite
there are 20 devices connected
Nov 26, 2018Guru - Experienced User
are they all connected to the router base or satelllite or mixed connections?
What FW is currently loaded?
Was the system working well before you added more devices?
- rezyNov 26, 2018Aspirant
they are probably connected to the base, I do not know how to connect them just to the satalite
what is fw?
yes the system was fine until I added amazon echo's
- FURRYe38Nov 26, 2018Guru - Experienced User
FW is Firmware.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. And how close are the devices to the router and satellites?
- rezyNov 26, 2018AspirantAbout 30 ft
Devices are scattered
