aaz
Oct 31, 2018Virtuoso
WiFi Protected setup with firmware 2.2.1.210
Has anyone successfully set up a device on the RBK50 running firmware 2.2.1.210 using WiFi protected setup?
I have an alarm system running a wifi connector and when I run 2.2.1.210 it refuses to co...
ekhalil
Nov 01, 2018Master
WPS works fine for me on 2.2.1.210.
Used WPS to connect my HP printer, LG TV and a D-Link Wifi extender.
aaz
Nov 01, 2018Virtuoso
Thanks - that helps - it may be just this particular device. That is unfortunate as it means this issue will die because of lack of attention. But thanks for the reply.
- ekhalilNov 02, 2018Master
Try -somehow- to reset the network on the device then try WPS again.
Does the device support WPS Push-Button or Pin method?
- aazNov 10, 2018Virtuoso
Hi, it's a push button method - not pin.
http://resolutionproducts.com/products/interactive-gateway-modules/wi-fi/
Thanks for your response - I just been too busy and have not checked the forum for a while.
I will call the alarm company and attempt a reset of the device still, because likely after reset they will need to reset it up.
- ekhalilNov 17, 2018Master
Have you had any luck with this?
I noticed that there is a parameter "Enable Enhanced WPS" in the debug page (orbilogin.net/debug). Can you please check if this is -somehow- ticked in your system?
