aaz
Oct 31, 2018Virtuoso
WiFi Protected setup with firmware 2.2.1.210
Has anyone successfully set up a device on the RBK50 running firmware 2.2.1.210 using WiFi protected setup?
I have an alarm system running a wifi connector and when I run 2.2.1.210 it refuses to co...
aaz
Nov 01, 2018Virtuoso
Thanks - that helps - it may be just this particular device. That is unfortunate as it means this issue will die because of lack of attention. But thanks for the reply.
ekhalil
Nov 02, 2018Master
Try -somehow- to reset the network on the device then try WPS again.
Does the device support WPS Push-Button or Pin method?
- aazNov 10, 2018Virtuoso
Hi, it's a push button method - not pin.
http://resolutionproducts.com/products/interactive-gateway-modules/wi-fi/
Thanks for your response - I just been too busy and have not checked the forum for a while.
I will call the alarm company and attempt a reset of the device still, because likely after reset they will need to reset it up.
- ekhalilNov 17, 2018Master
Have you had any luck with this?
I noticed that there is a parameter "Enable Enhanced WPS" in the debug page (orbilogin.net/debug). Can you please check if this is -somehow- ticked in your system?
