TominVirginia
Apr 09, 2018Follower
WiFi Range
I have the RBK50 system in my home. I have located the sat in a second floor room around 50ft away from the router. The connection between the two is fine. The sat is positioned on the outside ...
st_shaw
Apr 09, 2018Master
The sat is positioned on the outside wall in a glass window with an unobstructed "view" of the back yard. When I stand in the year around 50' from the house in the backyard I have marginal signal. Is there a usable "range" or maybe can someone explain the radiation pattern of the AP that might effect the usable range I am experiencing.
Thanks
I can get a usable signal 500' away from my house, with the Orbis inside the house. My windows are double-pane Andersens that were installed in 1989. Sounds like you may have low-e glass or glass with a similar energy efficient coating that can attenuate the WiFi signal.
NETGEAR makes an outdoor Orbi that you could hang on the outside of your house.
- Retired_MemberApr 09, 2018
something else to consider.....how many of your neighbors are on the same or nearby channel as you?
- tsigApr 10, 2018Luminary
Low e argon filled will attenuate your signals.
