TominVirginia
Apr 09, 2018Follower
WiFi Range
I have the RBK50 system in my home. I have located the sat in a second floor room around 50ft away from the router. The connection between the two is fine. The sat is positioned on the outside ...
Retired_Member
Apr 09, 2018something else to consider.....how many of your neighbors are on the same or nearby channel as you?
tsig
Apr 10, 2018Luminary
Low e argon filled will attenuate your signals.
