madbrain
Sep 27, 2017Luminary
Wifi roaming not seamless on Galaxy note 4
I'm using Orbi RBS50 in AP with two satellites, in a star setting (not daisy-chain, that setting is disabled). Firmware is 2.0.0.74 . I have recently added 13 Chromecast audios to my home for a w...
madbrain
Edit: did a short ping from a wired machine to the IP of the Note 4 (statically assigned by my wired Netgear R7000 DHCP server), and this was the result . It's on my desk 8ft from the main Orbi router.
ping -t 192.168.0.17
Pinging 192.168.0.17 with 32 bytes of data
Reply from 192.168.0.17: bytes=32 time=734ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1371ms TTL=64
Reply from 192.168.0.17: bytes=32 time=3ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1403ms TTL=64
Reply from 192.168.0.17: bytes=32 time=5ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1444ms TTL=64
Reply from 192.168.0.17: bytes=32 time=2ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1469ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1448ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1443ms TTL=64
Request timed out.
PING: transmit failed. General failure.
Reply from 192.168.0.17: bytes=32 time=2177ms TTL=64
Reply from 192.168.0.17: bytes=32 time=19ms TTL=64
Reply from 192.168.0.17: bytes=32 time=708ms TTL=64
Reply from 192.168.0.17: bytes=32 time=123ms TTL=64
Reply from 192.168.0.17: bytes=32 time=4ms TTL=64
Reply from 192.168.0.17: bytes=32 time=683ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1534ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.17: bytes=32 time=1432ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1462ms TTL=64
Reply from 192.168.0.17: bytes=32 time=612ms TTL=64
Reply from 192.168.0.17: bytes=32 time=361ms TTL=64
Reply from 192.168.0.17: bytes=32 time=1285ms TTL=64
Reply from 192.168.0.17: bytes=32 time=12ms TTL=64
Reply from 192.168.0.17: bytes=32 time=847ms TTL=64
Ping statistics for 192.168.0.17:
Packets: Sent = 38, Received = 32, Lost = 6 (15% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 2177ms, Average = 643ms
Control-C
^C
Definitely something very weird going on between my Note 4 phone and the Orbi router !
ping latency with devices much farther away (Chromecast audio) is much less, as is packet loss.
The Orbi device page is showing the Note 4 is attached to the Orbi main router using 5GHz band.
madbrain
As a test, I powered off the Orbi router and the two satellites. Then enabled the Wifi radio back on my R7000.
Did another short ping to the phone and this was the result.
Packets: Sent = 75, Received = 75, Lost = 0 (0% loss),
Minimum = 1ms, Maximum = 102ms, Average = 46ms
Still inconsistent latency, but at least zero packet loss or errors.
FYI, the R7000 and Orbi router and literally 3 feet apart, and wired to each other by a Gigabit cable. Was using Orbi router in AP mode and R7000 as wired router. Right now using R7000 for everything. But of course I don't have Wifi coverage everywhere around the house now, especially not outside, which is the main reason for Orbi. Coverage is useless if connection drops off, though.
- madbrainSep 27, 2017Luminary
FYI, I compared the Wifi settings in the R7000 (which was giving decent ping with the Note 4) to the Orbi .
Noticed the R7000 had 20/40 coexistence disabled, and Orbi had it enabled.
Also, R7000 had "long preamble" set, Orbi had it set to "auto".
I switched the Orbi settings to match the R7000.
Also rebooted my phone.
Then wireless switched radios back to Orbi (turned off R7000 wireless radio).
I first turned on the Orbi router only. Pings to the Note 4 seemed to be pretty reasonable at that point.
Then, I turned on the downstairs satellite (which is in a remote area with no wireless devices connected). After a couple reboots to uptake the Orbi router config change, ping to the Note 4 didn't change.
Then, I turned on the upstairs satellite, which has a bunch of Wifi devices hooked up (8 of the new Chromecasts). The moment I did that, the pings to the Note 4 started increasing dramatically, averaging 309ms.
Packets: Sent = 255, Received = 255, Lost = 0 (0% loss),
Minimum = 1ms, Maximum = 821ms, Average = 309msAt this time, I'm not experience any packet loss to the Note 4 or errors in the ping anymore. However, the latency is problematic, and it's probably the reason why I can't use Wifi calling on my phone without experiencing issues. I have not tried walking around the house with the phone yet to check the Wifi roaming. Speedtest app from the phone is relatively slow (44 Mbit down / 29 Mbps up, vs 200+/29 up wired). Speedtest ping claims only 12 ms, but local ping from Windows PC to the phone says otherwise.
After running for a bit longer, leaving the phone plugged in on my desk in the home office 8ft from the Orbi router, packet loss started again.
Packets: Sent = 982, Received = 916, Lost = 66 (6% loss),
Minimum = 1ms, Maximum = 2394ms, Average = 379ms
Control-C- st_shawSep 27, 2017Master
Check and make sure guest mode is OFF on every one of your chromecast devices.
