dwade
Dec 26, 2019Aspirant
WIFI signal strength varies
Hello! I'm a brand new Orbo user. 6 days in & the problems with my old system have been resolved. I do have a couple of minor problems. My WIFI signal meter will vary in strength. I don't ever s...
- Dec 26, 2019
That's just it......even when manually adding a network, my network didn't exist.
I've dealt with a fair number of hidden networks. Including all of my networks for the past decade. They never show up when scanning for available networks because they're hidden. That's completely normal & I get that.
I appreciate your help.
dwade
I tried to 'hide' the broadcast of my SSID in the advanced tab but it didn't just hide the SSID. It shut the WIFI down completely.
The reason: safety/security. No need to blast to everyone within reach of my signal.
Dec 26, 2019Guru - Experienced User
If your concerned about reach of your Orbi broadcast, you can turn down the wifi signal on the radios from 100% to say 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
dwade wrote:I tried to 'hide' the broadcast of my SSID in the advanced tab but it didn't just hide the SSID. It shut the WIFI down completely.
