mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
mkfein
Sep 30, 2019Star
Can you explain further? I'm not sure what this link is supposed to tell me? That there are other issues with V2.3.5.30 ?
Anonymous
Sep 30, 2019
mkfein wrote:Can you explain further? I'm not sure what this link is supposed to tell me? That there are other issues with V2.3.5.30 ?
Yes....others have been reporting problems since it's release. I'm amazed at the number of folks who have been in this community long enough to know this, yet they still insist on avoiding this possiblity.
- mkfeinSep 30, 2019StarIs there an alternative firmware version available that you recommend?
- AnonymousSep 30, 2019
My only recommendation is IF your system was working before your FW was updated (I'm assuming you did this manually) then I would try to revert back. My understanding is the NG stopped pushing FW updates UNLESS it contains major revisions needed by all. Otherwise a newer FW may be available but is NOT required (read the relase notes), especially if your system is working. Good luck.
