mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
ekhalil
Apr 04, 2020Master
Geddy007 wrote:
My problem was LG smart TV. I erased wifi internet connection from TV setup. After resetting router, the wifi speeds haven't dropped in over 3 weeks. Before, it routinely dropped every 2-3 days.
Go through everything connected to the router itself, disable one at a time, reset and wait to see what fixes it.
Good observation Geddy007. I think I've seen similar behaviour in my Orbi previously. What is special with this TV? Does it also have a wired connection to the network? Was it attached with Orbi previously as wired? Does the TV also act as an AP? Please look where this TV can cause loops in the network by having two different interfaces.
Geddy007
Apr 04, 2020Aspirant
TV was never wired - always wifi. It's not an AP that I know of. I never really even used the wifi connection, since all my entertainment comes through FireTV stick. The TV wifi connection was only used for the TV to get software updates for itself, which I don't really need. Now, if I want to check for a TV software update, I can manually connect to check and then erase wifi settings again.
- ekhalilApr 05, 2020Master
Geddy007 wrote:
TV was never wired - always wifi. It's not an AP that I know of. I never really even used the wifi connection, since all my entertainment comes through FireTV stick. The TV wifi connection was only used for the TV to get software updates for itself, which I don't really need. Now, if I want to check for a TV software update, I can manually connect to check and then erase wifi settings again.Then it must be a bad wifi module on your TV.
