mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
May 15, 2020Guru - Experienced User
The GS switch is a managed switch. try disabling ALL IGMP and green ethernet protocols on the switch. Can you connect the RBR directly to the ISP FTTH?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router.
Factory reset the RBR and setup from scratch with above suggestions.
Sylvain24 wrote:My Setup:
- SFR ISP (France) FTTH 1Gb DL / 500Mb Up.
-> Netgear GS105E-V2 last Firmware. -> Orbi RBK50 Only (Sat is not installed).
Drop speed is on both band: 2.4 and 5ghz, so the chanel is not an argument. Orbi firmware is 2.5.1.16, factory reset has been done a couple of version ago du to end support of separate SSID, but i had the drop speed issue before.
For me the drop speed is after on or two weeks, not days.
Sylvain24
May 15, 2020Tutor
Maybe instead trying to enable/disable everything on the router you may explain the reason for each component ;)
