mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
May 26, 2020Guru - Experienced User
Possible combination of FW, HW and environment. I tend to think more envrionment if you have tired other Orbi systems and they exhibit same problem.
Something to try, turn OFF the RBS and just run the RBR alone. Turn OFF all non priority devices, use just a few and check speeds over the few days. Then graduate adding some devices, keep in adding untill you notice something.
yototogblo
May 26, 2020Tutor
I should also note that I currently have the RBK50V and I don't Voxel's firmware works on that satellite (RBS40V satellite).
- FURRYe38May 26, 2020Guru - Experienced User
Ya, Voxels FW only works on the 50 series RBR and RBS.
Anyways, if you can't get what you have working, I'd return it and get into someting that does.
yototogblo wrote:I should also note that I currently have the RBK50V and I don't Voxel's firmware works on that satellite (RBS40V satellite).
