mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
Tbsteph
Jan 11, 2021Star
Dear Furry - This thread has been going on for about 1.5 years. Why do you feel the need to post your same canned response to this issue? It is not helpful or very enlightening.
At this point I believe it is readily obvious the RBR 50 has a significant problem for some users regarding wifi speeds dropping for no apparent reason. This issue has continued to plague many users through multiple firmware updates. Turning on/off various setting, hard resets, etc. does nothing to solve this problem (As indicated by many posts herein.).
Sorry for the rant but the tone of your post seems to want to blame the user for something Netgear should analyze and provide a fix.
fmalloy
Jan 11, 2021Luminary
Tbsteph wrote:Dear Furry - This thread has been going on for about 1.5 years. Why do you feel the need to post your same canned response to this issue? It is not helpful or very enlightening.
I have also experienced this on my RBR20, so it's not just your model. I suspect our models have some common HW/SW so the issue impacts multiple models. This is no surprise as every company does this; they don't design a similar model from scratch.
In any case, I suggest you start looking at every device that connects to the router - reset it, check it's network connection and SSID, reboot it, etc. I'm my case, I had a small Wi-Fi dongle that my satellite dish provider uses to download program guide updates and provide PPV. It's buried behind the satellite box so I forgot about it. I disconnected/reconnected the dongle, and re-entered the Orbi SSID into the satellite receiver, and since then I have not experienced the slowdown. My theory is the dongle somehow filled up some buffer after a few days and the slowdown happens. Just a theory...
The irony? The USB WiFi dongle is made by - NETGEAR.
Anyway - start looking at all the devices in your chain.
