mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
Jan 10, 2021Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Not seen on Orbi AX.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/1984296/jump-to/first-unread-message
fc7737 wrote:I have simiar problem.
I have Xfinity 100M internet service. My Orbi mesh router wireless attached devices become very slow speed every 7-10 days. They run less than 10-30mb/s when that happen. Wire attached devices are running fine.
After upgraded to V2.7.2.102, problem still exist... Now it happens consistanty every 2-3 days.
fc7737
Jan 14, 2021Aspirant
Hi Furry,
Thank you for your suggestions.
Yes, I have hard reset my Orbi every time I updated my FW.
NG online support suggested the following:
1. Select channel 11 for the 2.4 GHz and channel 48 for the 5 GHz.
2. In the WAN MTU Size field, enter 1479
After applied the changes, the wireless devices speed went back to 100M - possible due to wireless part got reset after config change.
However after 24-48hrs, my wireless devices speed went back to 25-30M...
I have provided my feedback back to NG support and waiting for reply..
- FURRYe38Jan 14, 2021Guru - Experienced User
Ok, thanks for letting us know. Ask about an RMA as well.
fc7737 wrote:Hi Furry,
