mkfein
Aug 02, 2019Star
WiFi Slow after 2-3 days until reboot?
I'm really at my wits end fighting with this Orbi System. I've read all the relevant forum posts I could find and am still struggling. I have 200 Mb/s service from Xfinity. Orbi RBR50 is connecte...
orbcad
Sep 04, 2021Guide
I have the exact same problem with my Orbi. About 3 or 4 days then speeds on the main router tank to 35mbps.
Only reboot fixes it. Very frustrating for such an expensive device. I had a cheap router before this that I needed to reboot 4 or 5 times a YEAR.
Sep 04, 2021Guru - Experienced User
