ErikVB13
Dec 20, 2021Aspirant
WIFI speed Drop since Oct 31st 2021
We have 500MB speed and have never had an issue. On Oct 31st we started to see drastically less speed from the router. I hook directly to the modem and I get 500mb on speedtest. THe speed test on Orbi is showing 90MB since.....
Am I missing something? Did a setting change?
I just checked this again today and I am still getting 500 on ROuter and only 90 on the mesh system.
PLEASE HELP
1 Reply
have you checked the cable between the modem and the router?
You can also check the wan port statistics.
this is for a nighthawk but should work on an orbi
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
